Hookline Single-Cutaway Electric Guitar Kit, Flamed Maple Veneer, Mahogany Body, Set-In Mahogany Neck, Rosewood Fretboard, Gold Hardware
SKU HKL1-RMRG-3
Current price $249.99 USD
$249.99 USD - $249.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Sep 11 – Sep 25 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
A set-in-neck DIY guitar kit built on our Hookline body, a pointed single-cutaway whose lower bout sweeps into a downward hook, topped with a flamed maple veneer. Solid mahogany body and mahogany neck, a bound rosewood fretboard with pearl-white parallelogram inlays, multi-ply ivory body binding and a full gold hardware set. The veneer takes a translucent stain or burst beautifully. The electronics ship loose rather than pre-wired, so this build includes soldering.
  • Orientation: Right-handed
Intermediate (7/10)
  • The flamed maple veneer is thin, so sand lightly and never power-sand the top, or you will cut through the figure
  • Top Veneer: Flamed Maple (front only, back is plain mahogany)
  • Body Binding: Multi-ply, ivory outer
  • Neck Binding: Ivory
  • Truss Rod: Double action, adjustable
  • Radius: 12" / 305mm
  • Inlay Shape: Parallelogram
  • Side Dots: Yes
  • Tuner Layout: 3+3
  • Tuner Holes: 10mm
  • Nut Width: 43mm
  • Wiring: Not pre-wired (soldering required)
  • Output Jack: Rear-mounted, upper bout
  • Finish: Gold
  • Tuners: Sealed diecast, 3+3
  • Knobs: Amber bell knobs
  • Truss Rod Cover: Black bell
  • Mahogany guitar body (unfinished) with flamed maple veneer top and multi-ply ivory binding
  • Gold Tune-O-Matic bridge and stopbar tailpiece with mounting studs
  • 4x amber bell knobs
  • Black bell truss rod cover
  • 2x gold strap buttons
  • Steel strings
Hookline Single-Cutaway Electric Guitar Kit, Flamed Maple Veneer, Mahogany Body, Set-In Mahogany Neck, Rosewood Fretboard, Gold Hardware is in stock.
