SKU E25-RPBG-4812
Original price $319 USD
Current price $279 USD
$279 USD - $279 USD
A thin singlecut hollow body kit with a Florentine cutaway and a slim 43.5 mm body depth. Lighter and more responsive than deeper hollow builds, this kit delivers classic archtop character with faster note response and improved feedback control. The laminated maple body with elegant f-holes, Ebonized fretboard with diamond inlays, and full gold hardware make it an ideal build for jazz, blues, soul, and clean melodic playing styles.
  • Material: Laminated Maple
  • Binding: White
  • Depth: 43.5 mm
  • Upper Bout: 310 mm
  • Waist: 250 mm
  • Lower Bout: 415 mm
  • Joint: Set-neck
  • Inlay Shape: Diamond
  • Binding: White
  • Bridge Pickup: None
  • Tailpiece: Gold Trapeze
  • Tuners: Sealed Diecast Gold
  • Knobs: Black Speed Knobs
  • Finish: Gold
  • Maple neck with Ebonized fretboard, diamond inlays, and white binding (unfinished)
  • Gold trapeze tailpiece
  • 2x black speed knobs
  • Gold output jack
  • Steel strings
1 humbucker, 1 volume, 1 tone
It has one humbucker at the neck, with one volume and one tone control.
