SKU DVH2-LMRC-1
Current price $179.99 USD
$179.99 USD - $179.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Aug 30 – Sep 13 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Left-handed Devil-Horn guitar kit with a mahogany body under a quilted maple veneer, a bolt-on mahogany neck, and a rosewood fretboard with trapezoid inlays. Standard 24 3/4" scale with 22 frets, two humbuckers, a Tune-O-Matic bridge with stopbar tailpiece, and chrome hardware.
  • Orientation: Left-handed
  • Inlay Material: Plastic
  • Shape: Blues Classic 3+3
  • Bridge: Tune-O-Matic with Stopbar Tailpiece
  • Hardware Finish: Chrome
What's in the Kit
  • 2x humbucker pickups
  • Chrome Tune-O-Matic bridge and stopbar tailpiece
  • Neck plate and screws
