Zebrawood EXP-style Guitar Kit
SKU EXP-RZZB-2
Current price $269.99 USD
$269.99 USD - $269.99 USD
Build your own DIY guitar kit with zebrawood body & neck, trapezoid inlays, and white pickguard and hardware.
  • Construction: Engineered wood
  • Nut: Black Plastic
  • Tuners: Black Sealed
  • Black stop tailpiece
  • White pickguard
  • Black truss rod cover
  • 3x black knurled knobs
  • Coil of green hookup wire
Unfortunately, Zebrawood EXP-style Guitar Kit is out of stock.
