L2 Semi-Hollow Basswood Guitar Kit with Spalted Maple Veneer
SKU LPH-RBOB-1
Original price $319.99 USD
Current price $269.99 USD
$269.99 USD - $269.99 USD
Build your own basswood semi-hollow body guitar using this DIY LP-style guitar kit with spalted maple veneer, dot abalone Inlays.
  • Material: Basswood (2-3 pcs)
  • Type: Semi-Hollow Chambered
  • Top Binding: Black
  • Inlay Material: Abalone
  • Tuners: Black Sealed
  • Semi-hollow body with a spalted-look figured veneer top, two f-holes and bound edges, unfinished
  • Neck with a dark brown fretboard and pearl-look dot inlays, unfinished
  • 6x black tuners with bushings and washers
  • 2x black-covered humbucking pickups
  • Black adjustable bridge
  • Black stop tailpiece
  • 2 pairs of black bridge and tailpiece mounting posts with anchor bushings
  • 4x black numbered speed knobs
  • Pre-wired harness with pots and coloured wire
  • 3-way toggle switch with a black tip and a chrome rhythm/treble washer
  • Black square jack plate with output jack
  • Set of strings
  • Assorted screws, nuts and washers
L2 Semi-Hollow Basswood Guitar Kit with Spalted Maple Veneer is on pre-order.
