SKU JG-RMRC-1
Original price $279 USD
Current price $229 USD
$229 USD - $229 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 27 – Dec 11 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Adjustable bridge
  • White plastic nut
  • Red tortoise pickguard
  • 2x black control knobs
Short-scale JG style Guitar Kit with Mahogany Body, Rosewood Fretboard is in stock.
It has two humbuckers, one at the neck and one at the bridge.
