SKU LP-RMPC-29
Original price $259 USD
Current price $219 USD
$219 USD - $219 USD
  • Knobs: Black Speed Knobs
  • 4x black speed knobs
  • Toggle switch plate
  • Strap pins
  • Neck plate and screws
It has a one-piece wraparound bridge with six saddles you can adjust. The strings attach to the bridge itself, so there is no separate tailpiece. There is no tremolo arm.
What is the fretboard like?
The fretboard is light maple with black dot markers.
