SKU DVH2-LMRC-1
Original price $299 USD
Current price $179 USD
$179 USD - $179 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 27 – Dec 11 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Left-handed Devil-Horn guitar kit with a mahogany body under a quilted maple veneer, a bolt-on mahogany neck, and a rosewood fretboard with trapezoid inlays. Standard 24 3/4" scale with 22 frets, two humbuckers, a adjustable bridge with stopbar tailpiece, and chrome hardware.
  • Dexterity: Left-Handed
  • 2x humbucker pickups
  • Neck plate and screws
Is this kit left-handed?
