Rounded Double-Cut Marblo Electric Guitar Kit with Double-Locking Tremolo, Quilted Maple Veneer, Basswood Body, Maple Fretboard
SKU MA-RBPC-1
Original price $259 USD
Current price $199 USD
$199 USD - $199 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 9 – Dec 23 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Secure, encrypted checkout.
A rounded double-cut body with a deep cutaway and a double-locking tremolo, in one kit. The Marblo body has two rounded horns, a deep cutaway beside the neck and a full lower bout with no sharp points. The locking nut comes already fitted to the neck.
The double-locking tremolo clamps each string at the bridge, and the locking nut clamps them again at the headstock, so the guitar is built to hold its tuning through heavy whammy bar use once it is set up. Fine tuners on the bridge handle small corrections after the strings are locked. The body is pre-routed for the floating tremolo, its springs and both humbuckers.
The wiring is short: two zebra humbuckers, with one cream and one black coil each, run through one volume knob and a 3-way toggle, with no tone pot. The basswood body carries a quilted maple veneer on the top, left bare for the finish you choose. The bolt-on maple neck has a maple fretboard with 22 frets, black dot inlays, side dots and rounded fret ends, with chrome hardware throughout.
Marblo is a name we built from marble, the stone that wears smooth and round. The body has the same soft outline: two rounded horns, a full lower bout and no sharp points. The quilted maple top is left bare for you to finish your way.
  • Setting up the floating double-locking tremolo: spring tension, string locking and fine tuners take patience.
  • The quilted maple veneer is thin, so sand the top lightly and by hand to avoid sanding through.
  • Soldering two humbuckers to one volume pot and a 3-way toggle.
  • Easier than a set-neck build: the bolt-on neck, the pre-cut routes and the pre-fitted locking nut take care of the woodwork.
  • Top: Quilted Maple
  • Joint: Bolt-on (4 screws)
  • Truss Rod: Two-Way, Adjustable(adjusted at the heel)
  • Truss Rod Adjustment: Heel
  • Fret Ends: Rounded
  • Inlay Color: Black
  • Side Dots: Yes
  • Nut: Locking nut, pre-installed
  • Neck Pickup: Humbucker (zebra, with mounting ring)
  • Bridge Pickup: Humbucker (zebra, with mounting ring)
  • Controls: 1 Volume, 3-way toggle
  • Bridge: Double-locking tremolo (floating, with fine tuners and whammy arm)
  • Tuners: 6 sealed tuners
  • Knobs: 1 chrome dome knob
  • Cavity Covers: Black (tremolo and control cavities)
  • Strings: Included
  • 1x Basswood body with quilted maple veneer, pre-routed
  • 1x Maple neck with maple fretboard and pre-installed locking nut
  • 6x Tuners with bushings and washers
  • 2x Zebra humbuckers with mounting rings, springs and screws
  • 1x Volume pot, 1x 3-way toggle switch and wiring
  • 1x Output jack with plate
  • 1x Chrome dome knob
  • 1x Double-locking tremolo with 2x anchor studs and whammy arm
  • 3x Tremolo springs, 1x spring claw and screws
  • 1x String retainer bar
  • 4x Neck screws with ferrules
  • 2x Strap buttons
  • 1x Tremolo cavity cover and 1x control cavity cover, with screws
  • Allen keys for the tremolo and locking nut
  • 1x Set of strings
  • 1x Guitar cable
  • For setup: String winder, guitar tuner, Allen wrench for truss rod adjustment and tremolo setup
No woodworking or routing required: all cavities, holes, and channels are pre-cut.
Compare our other double-locking tremolo kits: the set-neck kit with quilted maple veneer and the mahogany kit with vinework inlays. Or browse the full range of quilted maple guitar kits.
Rounded Double-Cut Marblo Electric Guitar Kit with Double-Locking Tremolo, Quilted Maple Veneer, Basswood Body, Maple Fretboard is in stock.
What does the double-locking tremolo do on this kit?
It clamps the strings at the bridge and at the pre-installed locking nut, so heavy whammy bar use does not pull the guitar out of tune once it is set up. Fine tuners on the bridge handle small pitch corrections after the strings are locked.
How is this kit different from your other double-locking tremolo kits?
This one pairs a bolt-on maple neck with a basswood body under a quilted maple veneer. For a set-in neck, see the set-neck kit with quilted maple veneer; for a mahogany body, see the mahogany kit with vinework inlays.
How hard is this guitar kit to build?
It is rated Intermediate, 6 out of 10. The parts that take care are setting up the floating tremolo and sanding the thin quilted maple veneer by hand; the bolt-on neck and pre-cut routes keep the woodwork simple. See how we score build difficulty.
What are the neck and scale length specs?
The maple neck has a 25.5 inch (648 mm) scale, a maple fretboard with 22 frets and rounded fret ends, black dot inlays and side dots. The truss rod is adjusted at the heel.
