Stripewood EXP-style Guitar Kit
SKU EXP-RZZB-2
Current price $269.99 USD
$269.99 USD - $269.99 USD
Build your own DIY guitar kit with Stripewood body & neck, trapezoid inlays, and white pickguard and hardware.
Stripewood is our name for this wood. The factory dyes thin sheets of wood, glues them into a block, and shapes it. So the stripes run all the way through, not only on top. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test inside a cavity first.
  • Nut: Black Plastic
  • Tuners: Black Sealed
  • Black stop tailpiece
  • White pickguard
  • Black truss rod cover
  • 3x black knurled knobs
  • Coil of green hookup wire
Unfortunately, Stripewood EXP-style Guitar Kit is out of stock.
