Custom Shop Thin Hollow Body Electric Guitar Kit, Venetian Cutaway
Original price $449 USD - Original price $449 USD
$449 USD
$449 USD - $449 USD
Current price $449 USD
SKU L3-C-1
Product Details:
Thin Hollow Body Venetian Cutaway Guitar Kit to create your dream DIY semi-acoustic electric guitar. Customize the tonewood, choose your hand orientation, install your preferred hardware setup, and many more to create your own unique instrument that money cannot buy.
Description
  • Body Type: Hollow Body
  • Fretboard Radius: 14" / 356 mm
  • Cutaways: Single
  • Pickups: 2 Humbuckers
  • Bridge Type: Adjustable bridge with Stopbar
  • String: Steel
  • Machine Heads: Closed
  • Vibrato bar/ Tremolo: Tremolo
  • Body Depth: 43.5 mm
  • Body Upper Bout: 310 mm
  • Body Waist: 248 mm
  • Body Lower Bout: 415 mm
Delivery Timeline:
If you wish to cancel your Custom Shop order, please do so within 5 days to avoid a $150 cancellation fee. Learn more about ourĀ Refund policy.
Shipping Information:
Assembly Instructions:
Safety First: It is recommended to sand and finish your kit guitar in a well-ventilated area wearing a respirator mask. You can learn more about the safety tips that you need to follow by clicking here:Ā Important Guitar Finishing Safety Tips That You Must Follow.
Loading custom options...
It has two humbuckers, one at the neck and one at the bridge.
