Hollow Body Archtop Electric Guitar Kit, Alder Body, Rosewood Fretboard, Left-Handed
SKU E175-LARC-1
Original price $329 USD
$329 USD
$329 USD - $329 USD
Current price $329 USD
Build your own left-handed Hollow Body Guitar with Rosewood Fretboard using our DIY Guitar kits.
  • Dexterity: Left-Handed
  • Material: Laminated Maple Top & Sides, Alder Center Block
  • Internal Support: Bridge block, Alder
  • Cutaway: Single, Florentine style
  • Binding: Black, Multi-ply
  • Binding: Single White
  • Width at 5th Fret: 46 mm
  • Width at 9th Fret: 49 mm
  • Width at 12th Fret: 52 mm
  • Width at 22nd Fret: 56 mm
  • Shape: Blank (Not Drilled)
  • Hollow archtop single-cutaway guitar body, unfinished, with two f-holes and body binding
  • Neck with rosewood fretboard (frets installed), green abalone pearloid block inlays and an uncut paddle headstock blank with no tuner holes drilled
  • 2x chrome-covered humbucker pickups with six pole screws each, in black mounting rings
  • Chrome adjustable bridge with six saddles
  • 2x chrome bridge posts with thumbwheels
  • Pre-wired harness with four potentiometers and red, yellow and black hookup wire
  • 4x chrome dome knobs
  • Output jack
  • Chrome L-shaped mounting bracket
  • 2x strap buttons with washers and mounting screws
Unfortunately, Hollow Body Archtop Electric Guitar Kit, Alder Body, Rosewood Fretboard, Left-Handed is out of stock.
