Hookline Pointed Single-Cutaway Electric Guitar Kit, Mahogany Body, Flamed Maple Veneer, Bolt-On Mahogany Neck, Ebony Fretboard
SKU HKL1-RMEB-1
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
  • Bolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the flamed Maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Top Veneer: Flamed Maple
  • Binding: White
  • Material: Ebony
  • Inlay Shape: Block
  • Nut: Ivory Plastic
  • Unfinished routed guitar body with a figured top
  • Neck with dark fretted fingerboard and large pearl-look block inlays
  • 6x black sealed tuners with black bushings and washers
  • 2x black covered humbuckers in black mounting rings
  • Pre-wired harness with four potentiometers and a toggle switch
  • Black stop tailpiece
  • Black bridge with individually adjustable saddles
  • 2x bridge posts and 2x tailpiece studs
  • 4x black numbered knobs
  • Output jack on a black jack plate
  • Large angular black control cavity cover
  • Round black switch cavity cover
  • Black neck plate with 4 screws
Hookline Pointed Single-Cutaway Electric Guitar Kit, Mahogany Body, Flamed Maple Veneer, Bolt-On Mahogany Neck, Ebony Fretboard is on pre-order.
