Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Ash Body, Stripewood Veneer, Ebonized Fretboard
SKU TEH-RSBC-1
Original price $289 USD
Current price $269 USD
$269 USD - $269 USD
Semi-Hollow T-style guitar kit with Ash Body, Stripewood (Reconstituted Wood) body top, and Maple neck. Shop now to build your own DIY guitar!
Stripewood is our name for this wood veneer. The factory dyes cottonwood, a type of poplar, then glues and presses it in layers with heat and pressure so it looks striped. No resin is used. Here it is sliced into a thin top. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test on a hidden spot first.
  • Stripewood veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Ash (2-3 pieces)
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Top: Stripewood veneer (reconstituted wood, thin sheet)
  • Bridge: Hardtail
  • Pickguard: Pearl White
  • Semi-hollow body with f-hole, unfinished, with pearl-white pickguard and two chrome-covered humbuckers already fitted
  • Neck with dark fretboard and white dot inlays, unfinished
  • Chrome six-saddle fixed bridge with mounting screws
  • Pre-wired wiring harness with 3-way lever switch and potentiometer
  • 2x chrome dome knobs
  • 2x chrome strap buttons with screws
  • Set of strings
  • 2x truss rod adjustment wrenches
Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Ash Body, Stripewood Veneer, Ebonized Fretboard is on pre-order.
