Mahogany Body LP-Style Guitar Kit with P90 Pickups with Black Hardware
SKU LP-RMRB-439
Current price $239.99 USD
$239.99 USD - $239.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Sep 16 – Sep 23 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
Build your own classic LP-style guitar with this DIY electric guitar kit. Designed for right-handed players, it features a solid mahogany body and set-in mahogany neck for rich sustain and resonance. The Ebony (Engineered) fretboard with trapezoid inlays provides smooth playability, while the C-shaped neck ensures comfort.
  • Set-in neck has to be aligned and glued before finishing, and that joint is what most affects intonation
  • Tune-o-matic bridge and stopbar tailpiece set intonation quickly once the posts are seated
  • Two volume and two tone controls plus a toggle switch mean plenty of soldered joints to keep tidy in the cavity
  • Shape: Classic blues, no binding
  • Neck Pickup: P90 soapbars (black, single-coil)
  • Bridge Pickup: P90 soapbars (black, single-coil)
  • Controls: 2 Volume, 2 Tone, 3-way toggle
  • Wiring Diagram: 2x P90, 2 Volume, 2 Tone, 3-Way Switch
  • Knobs: Black plastic top-hat style
  • Strings: Standard Steel
  • Finish: Black set (tuners, bridge, tailpiece, etc.)
  • Mahogany single-cutaway guitar body (unfinished)
  • Guitar neck with rosewood fretboard and pearl trapezoid inlays (unfinished)
  • 2x black P90 soapbar pickups
  • Black tune-o-matic style bridge with posts and thumbwheels
  • 4x black top-hat knobs
  • Black 3-way toggle switch with washer plate
  • Output jack with wiring
  • Black round rear control cavity cover
  • Black truss rod cover
  • Set of guitar strings
Mahogany Body LP-Style Guitar Kit with P90 Pickups with Black Hardware is in stock.
