SKU E35-RPRC-759
Original price $319 USD
Current price $279 USD
$279 USD - $279 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 4 – Nov 11 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your dream semi hollow electric guitar with this flame maple top DIY kit featuring HH humbuckers, set in mahogany neck, abalone pearloid block inlays and Tune O Matic with trapeze tailpiece. Ideal for jazz, blues and classic rock builders.
  • Material: Laminated Maple
  • Type: Semi-Hollow
  • Top Binding: Multi-ply White
  • Back Binding: Single White
  • Binding: Single White
  • Inlay Shape: Block
  • Controls: 2V, 2T, 3-Way
  • Semi-hollow body with a figured maple top, two f-holes, ivory binding, routed for two humbuckers
  • Neck with a dark fretboard and rectangular abalone pearloid block position markers, nut fitted
  • 2x chrome-covered humbucker pickups in black mounting rings
  • 1x chrome adjustable bridge with two mounting posts and thumbwheels
  • 1x chrome trapeze tailpiece with its mounting plate
  • 1x black truss rod cover with two screws
  • 4x black numbered barrel knobs
  • 1x pre-wired harness with four potentiometers, a toggle switch and an output jack
  • 1x group of chrome nuts and washers for the potentiometers and jack
  • 1x Allen wrench
  • 1x group of assorted chrome screws
Semi-Hollow Double-Cutaway Electric Guitar Kit, Flame Maple Veneer is in stock.
It has an adjustable bridge that stands on two posts, and a separate trapeze tailpiece. The tailpiece holds the string ends at the bottom of the body.
Is the body hollow or solid?
It is semi-hollow, with a solid center block inside and two f-holes on the top.
