SKU JG-RMRB-5103
Original price $279.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 2 – Oct 9 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Black adjustable bridge
  • White plastic nut
  • 2x black control knobs
