Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Ash Body, Engineered Zebrawood Veneer, Engineered Ebony Fretboard
SKU TEH-RSBC-1
Current price $269.99 USD
$269.99 USD - $269.99 USD
Semi-Hollow T-style guitar kit with Ash Body, Zebrawood (Engineered) body top, and Maple neck. Shop now to build your own DIY guitar!
  • Zebrawood (Engineered) veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Ash (2-3 pieces)
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Top: Engineered zebrawood veneer (thin sheet)
  • Bridge: Hardtail
  • Pickguard: Pearl White
  • Semi-hollow body with f-hole, unfinished, with pearl-white pickguard and two chrome-covered humbuckers already fitted
  • Neck with dark fretboard and white dot inlays, unfinished
  • Chrome six-saddle fixed bridge with mounting screws
  • Pre-wired wiring harness with 3-way lever switch and potentiometer
  • 2x chrome dome knobs
  • 2x chrome strap buttons with screws
  • Set of strings
  • 2x truss rod adjustment wrenches
Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Ash Body, Engineered Zebrawood Veneer, Engineered Ebony Fretboard is on pre-order.
