Double-Cutaway Contoured Electric Guitar Kit, Stripewood Body, Rosewood Fretboard, Black Hardware
SKU ST-RZEB-1
Original price $289 USD
Current price $239 USD
$239 USD - $239 USD
Ready to add a new badge to your DIY hall of fame? Our Stripewood ST style body Guitar kit with a Rosewood fretboard is ready to roll with you. Put your craftsmanship to the test and create your very own right-handed guitar, featuring a bolt-on neck and 22 frets. It's practically a symphony of wood, eagerly waiting to play your tune. Time to pull out those tools and let the music begin!
  • Striped engineered-wood guitar body, double-cutaway and contoured, with a black pickguard already fitted
  • Black pickguard assembly with three black single-coil pickups, three black numbered knobs, a blade selector switch and wiring
  • Neck with rosewood fretboard (frets installed) and dot inlays
  • Black tremolo bridge with six saddles and a sustain block
  • Black tremolo arm
  • Tremolo spring claw with two mounting screws
  • 3x springs
  • Black back cover plate with six string slots
  • Black rectangular back cover plate
  • Black boat-shaped jack plate with output jack fitted
  • 2x black strap buttons
Double-Cutaway Contoured Electric Guitar Kit, Stripewood Body, Rosewood Fretboard, Black Hardware is in stock.
It has three single-coil pickups, with one volume, two tone controls and a pickup selector switch.
