SKU LP-RMPC-29
Original price $259.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Oct 22 – Nov 5 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Knobs: Black Speed Knobs
  • 4x black speed knobs
  • Toggle switch plate
  • Strap pins
  • Neck plate and screws
