SKU BLK-WB-A
Original price $269.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
  • Number of Strings: 4
  • Scale Length: 864 mm / 34"
  • Radius: 12" / 305mm
  • Number of Frets: 24
  • Pickups: PJ-style Bass
  • Bridge: Bass Bridge
  • Cavity Covers: White
  • Black bar-style bass pickup
  • 3x chrome dome knobs
  • 3x pot nuts and 3x washers
  • White teardrop pickguard
  • Coiled bass string set
  • Assorted screws
Woodworking required. You cut the body outline from a squared blank, cut the headstock outline and drill its tuner holes, and drill the output jack hole yourself. The neck pocket, pickup and control cavities are already routed, and the electronics need soldering.
