SKU BLK-WB-A
Original price $269.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 11 – Nov 25 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Number of Strings: 4
  • Scale Length: 864 mm / 34"
  • Radius: 12" / 305 mm
  • Number of Frets: 24
  • Pickups: PJ-style Bass
  • Bridge: Bass Bridge
  • Cavity Covers: White
  • Black bar-style bass pickup
  • Pre-wired potentiometers with colored wiring loom
  • 3x chrome dome knobs
  • 3x pot nuts and 3x washers
  • White teardrop pickguard
  • Coiled bass string set
  • Assorted screws
Woodworking required. You cut the body outline from a squared blank, cut the headstock outline and drill its tuner holes, and drill the output jack hole yourself. The neck pocket, pickup and control cavities are already routed, and the electronics need soldering.
