SKU BLK-ST-B
Original price $229.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 11 – Nov 25 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Controls: 1 Volume, 2 Tone
  • 1x chrome neck plate
  • 4x neck mounting screws
  • 1x tremolo arm
  • 2x strap buttons
