Semi-Hollow Offset Electric Guitar Kit, Quilted Maple Veneer, Mahogany Body, Rosewood Fretboard
SKU OH-RMRC-814
Current price $279.99 USD
$279.99 USD - $279.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 6 – Nov 20 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build a semi-hollow electric guitar with an offset double-cutaway body, a mahogany body and neck, and a quilted maple top. Two f-holes open up the body, and a full-length center block runs underneath, so it has the airy voice of a hollow guitar while resisting feedback at higher volume. Multi-ply ivory binding is already fitted around the body and the headstock.
The mahogany neck glues into the body rather than screwing on. Lining it up and gluing it is the step that takes the most care, which makes this a kit for builders with some experience. The neck carries a rosewood fretboard with 24 stainless steel frets, pearl white Flock inlays and a bone nut. Stainless steel frets stay smooth and wear far more slowly than standard nickel-silver frets.
Two humbucking pickups run through two volume knobs, two tone knobs and a 3-way toggle switch, with the output jack on the side of the body. You solder the connections yourself, following our wiring diagram for this exact layout. A Tune-o-matic bridge with a stop bar tailpiece and chrome sealed tuners complete the hardware. The body and neck come unfinished, ready for whatever color you choose.
  • Type: Semi-Hollow
  • Binding: Multi-ply Ivory
  • Number of Frets: 24
  • Inlay Shape: Flock
  • Wiring: DIY (soldering required, not pre-wired)
  • Bridge: Tune-o-matic + Stop Bar Tailpiece
  • Semi-hollow body with figured maple top, two f-holes, bound edges and a routed center block
  • Neck with rosewood fretboard, frets and pearl white Flock inlays
  • 2x black humbucker pickups with black mounting rings
  • 4x pots and colored hook-up wire (not pre-wired, soldering required)
  • Chrome rectangular jack plate with output jack
  • Chrome Tune-o-matic bridge with six adjustable saddles
  • Chrome stop bar tailpiece
  • 4x black numbered knobs
  • 2x strap buttons
  • Coiled set of strings
Semi-Hollow Offset Electric Guitar Kit, Quilted Maple Veneer, Mahogany Body, Rosewood Fretboard is in stock.
Find the diagram for your kit
