Double-Cutaway Semi-Hollow Electric Guitar Kit, Alder Body, Quilted Maple Veneer
SKU STH-RARC-0510
Original price $259 USD
Current price $233 USD
$233 USD - $233 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 25 – Jan 8 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build Your Own Alder Body Semi-hollow S-style Guitar Kit with Quilted Maple Veneer using our DIY Guitar Kits.
  • Material: Alder
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Binding: Single White
  • Pickguard: Pearl White
  • Knobs: White
  • Cavity Covers: White
  • 1x pearl-white pickguard with three white single-coil pickups, three white skirted knobs and a white switch tip installed
  • 1x chrome vibrato bridge with six saddles and a steel block
  • 1x chrome vibrato arm
  • 1x tremolo spring claw with three springs and two mounting screws
  • 1x pearl-white tremolo backplate with string slot
  • 1x chrome neck plate with four screws
  • Assorted chrome mounting screws
Double-Cutaway Semi-Hollow Electric Guitar Kit, Alder Body, Quilted Maple Veneer is in stock.
Is the body hollow or solid?
It is semi-hollow. The body is solid wood with hollow chambers inside and one f-hole on the top.
