SKU JG-RMRB-5103
Original price $279 USD
Current price $219 USD
$219 USD - $219 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 11 – Nov 18 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
  • Black adjustable bridge
  • White plastic nut
  • 2x black control knobs
It has two humbuckers, one at the neck and one at the bridge.
