Mahogany body, Bolt-On Neck NI-style Guitar Kit with Quilted Maple Veneer
SKU NI-RMFB-5264
Original price $269 USD
Current price $189 USD
$189 USD - $189 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 11 – Nov 18 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own bolt-on neck Mahogany NI-style Guitar with Quilted Maple Veneer.
  • No binding, so no masking is needed when finishing
  • Number of Frets: 24
  • Nut: Black Locking Nut
  • Controls: 2 Volume, 2 tone, 3-way Toggle
  • Bridge: Locking Tremolo
  • Tuners: Sealed
  • Knobs: Black (dome)
  • Unfinished mahogany body with a quilted maple veneer top, routed for two humbuckers and a recessed tremolo
  • Unfinished maple neck with maple fretboard, dot position markers and a black locking nut already fitted
  • 2x black humbucker pickups
  • 1x wiring harness with 4 potentiometers, a 3-way toggle switch and output jack (soldering required)
  • 1x black double-locking tremolo bridge with two mounting posts
  • 1x black tremolo arm
  • 3x tremolo springs with a chrome spring claw and two claw screws
  • 6x black sealed tuners with bushings
  • 4x black dome knobs
  • 1x black rear control cavity cover plate
  • 1x black rear spring cavity cover plate with a slot
  • 1x black oval jack plate
  • 1x black truss rod cover with screws
  • 4x black neck mounting screws with four black ferrules
  • 2x black strap buttons with screws and washers
  • Assorted black screws
  • Allen wrenches
Mahogany body, Bolt-On Neck NI-style Guitar Kit with Quilted Maple Veneer is in stock.
It has a locking tremolo with an arm. The strings clamp down at the bridge and at a locking nut at the top of the neck.
