Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Rosewood Fretboard, Left-Handed
SKU ST-LXXB-209
Original price $239 USD
Current price $179 USD
$179 USD - $179 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 11 – Nov 18 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own left-handed S-style electric guitar with this high-quality DIY guitar kit, designed for smooth playability and classic tone. Featuring a solid two-piece mahogany body and a bolt-on maple neck with a 25.5ā€ scale length, this kit delivers balanced resonance and comfortable feel. The rosewood fretboard with a 9.5" radius and white dot inlays ensures easy fretting across all 21 frets. Equipped with three single-coil pickups, a 5-way selector, and Vintage-style tremolo bridge, this kit is perfect for builders looking for iconic tones and customization freedom.
  • Dexterity: Left-Handed
  • Radius: 9.5" / 241 mm
  • Knobs: White
  • Cavity Covers: White
  • Unfinished left-handed body routed for a pickguard and a vibrato
  • Neck with dark fretboard, dot position markers and a drilled headstock
  • 1x sealed bag holding a guitar cable and a vibrato arm
  • 1x sealed bag holding a vibrato bridge assembly with saddles
  • 1x sealed bag holding six tuners
  • 1x sealed bag holding vibrato springs and a claw
  • 1x sealed bag holding a coil of strings
  • 1x sealed bag holding long mounting screws
  • 1x sealed bag holding assorted small screws
  • 3x sealed bags holding small metal hardware parts
  • 1x sealed bag holding a dark metal part
  • 1x printed thank you card
Double-Cutaway Contoured Electric Guitar Kit, Mahogany Body, Rosewood Fretboard, Left-Handed is in stock.
Is this kit left-handed?
It has three single-coil pickups. The controls are one volume, two tone and a pickup switch.
