You wire the pickups, the controls and the output jack yourself. Every connection is a wire
onto a lug, all of them inside one cavity, and you can redo any of them. Soldering is a skill
you pick up in an afternoon, not a trade you need to have already.
1 humbucker, 1 volume
See the
wiring diagram for this kit. That is the community thread for this exact layout, so you
can ask about your build there and get an answer against a photo of your own cavity.
Just want the file?
Download
the diagram.
A soldering iron, rosin-core solder and wire cutters. None of it is specialist equipment and
none of it is included in the kit.
Start with our
guide
to guitar electronics. It covers what each component does and how to make a joint that
holds. If a joint fails you can heat it and redo it. Nothing in the electronics is single use.
It happens. Kits vary slightly between production runs in wire colours and occasionally in
components, which can make a general diagram confusing. You are not misreading it.
Send us your order number with a close-up of the wiring harness and a wider shot of the whole
control cavity, and our wiring technician will send you the correct diagram for your kit or
draw one for it.
Would rather not solder at all?
See the kits that arrive wired.
