Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebonized Fretboard, Chrome Hardware
SKU L5-RMEC-2
Original price $319.99 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 19 – Oct 26 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own Hollow Archtop Body Guitar with Ebonized Fretboard using our DIY Guitar Kits.
  • Inlay Shape: Diamond
  • Shape: Semi-styled, 3+3
  • Bridge Pickup: None
  • Knobs: Black Plastic
  • Neck with black fretboard (frets installed) and split-block white pearloid inlays
  • Output jack
  • Black triangular jack plate
Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebonized Fretboard, Chrome Hardware is in stock.
1 humbucker, 1 volume, 1 tone
