Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Mahogany Body, Flame Maple Veneer, Black Hardware
SKU TEH-RMRB-1
Current price $259.99 USD
$259.99 USD - $259.99 USD
Build a versatile semi-acoustic TE-style guitar designed for players who want both classic tone and modern flexibility. The mahogany semi-hollow body with flamed maple veneer delivers warm resonance with clear articulation, making it ideal for blues, jazz, indie, rock, country, and studio session work. Dual humbuckers and a 3-way toggle allow a wide tonal range from smooth cleans to punchy overdrive, while the comfortable C-shaped maple neck and bolt-on design make it approachable for beginners yet satisfying for experienced builders. Whether used for live performance, recording, practice, or customization projects, this kit offers a reliable platform for crafting a personalized instrument that looks distinctive and performs across multiple musical styles.
  • Flamed Maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Top Veneer: Flamed Maple
  • Scale Length: 648 mm / 25.5″
  • Bridge: Fixed
  • Pickguard: Black Pearloid
  • Thin semi-hollow guitar body with a figured maple top veneer and one f-hole, unfinished
  • Black pickguard fitted to the body with two black pickups mounted in it
  • Guitar neck with dark fretboard and face dot markers
  • Black hardtail bridge with 6 saddles
  • Pre-wired control harness on a metal control plate with potentiometers
  • Black square jack plate with output jack
  • 2x black domed knobs
  • Black neck plate with 4 long black mounting screws
  • Set of strings
  • Assorted black screws
  • Hex nuts and washers
Thin Semi-Hollow Single-Cutaway Electric Guitar Kit, Mahogany Body, Flame Maple Veneer, Black Hardware is on pre-order.
