Stripewood EXP-style Guitar Kit with Trapezoid Fretboard Inlays
SKU EXP-RZZB-1
Current price $239.99 USD
$239.99 USD - $239.99 USD
Build your own DIY guitar kit with Stripewood body & neck, trapezoid inlays, and black pickguard and hardware.
Stripewood is our name for this wood. The factory dyes thin sheets of wood, glues them into a block, and shapes it. So the stripes run all the way through, not only on top. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test inside a cavity first.
  • Nut: Black Plastic
  • Tuners: Black Sealed
  • Black stop tailpiece
  • Black truss rod cover
  • 3x black knurled knobs
Stripewood EXP-style Guitar Kit with Trapezoid Fretboard Inlays is on pre-order.
