Thin Hollow Body Electric Guitar Kit, Venetian Cutaway, Flame Maple Veneer
SKU L3-RMRC-835
Original price $299 USD
Current price $269 USD
$269 USD - $269 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 21 – Jan 4 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own Thin Hollow Body Venetian Cutaway Guitar Kit with Rosewood Fretboard and Flame Maple Veneer using our DIY Guitar kits.
  • Material: Laminated Maple
  • Binding: Multi-ply Black
  • Inlay Shape: Split Parallelogram
  • Tuners: Sealed, Diecast, Chrome
  • Knobs: Black Plastic
  • Hollow body with flame maple veneer top, two f-holes and a bound edge
  • Neck with dark fretboard, frets and block inlays, and an unpainted headstock
  • 2x chrome-covered humbucker pickups with black mounting rings
  • Pre-wired harness with four pots and colored wiring
  • 3-way toggle switch with ivory tip, nut and washer
  • Black RHYTHM / TREBLE toggle washer ring
  • Chrome adjustable bridge with six saddles
  • Chrome stop bar tailpiece
  • 4x chrome posts and 2x thumbwheels for bridge and tailpiece
  • 4x black numbered knobs
  • Black truss rod cover with screw
  • Chrome L-shaped jack bracket with output jack
  • Coiled set of strings
Thin Hollow Body Electric Guitar Kit, Venetian Cutaway, Flame Maple Veneer is in stock.
Is the body solid wood?
No. The body is made of laminated wood, which is thin layers glued together. It has two f-holes and a thin flamed maple veneer on the top.
