Hollow Body Archtop Electric Guitar Kit, Single Florentine Cutaway, Quilted Maple Veneer, Left-Handed
SKU E175-LMEG-1
Original price $309 USD
Original price $309 USD - Original price $309 USD
Current price $229 USD
$229 USD - $229 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 26 – Dec 3 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Build your own left-handed DIY hollow body guitar with Mahogany Body and Neck, Quilted Maple veneer, F-Holes, and Florentine-style single cutaway.
  • Dexterity: Left-Handed
  • Material: Laminated Maple
  • Cutaway: Florentine-style Single
  • Binding: Multi-ply
  • Width at 5th Fret: 46 mm
  • Width at 9th Fret: 49 mm
  • Width at 12th Fret: 52 mm
  • Width at 22nd Fret: 56 mm
  • Shape: Semi-styled, 3+3
  • Controls: 2 Volume, 2 Tone, 3 Way Switch
  • Tuners: Gold Sealed
  • Pickguard: Pearl White
  • Knobs: Gold
  • Finish: Gold
  • Hollow archtop body with a figured light veneer top, two f-holes and bound edges, unfinished
  • Neck with a black fretboard and white pearloid block inlays, unfinished
  • 6x gold tuners with bushings and washers
  • 2x gold-covered humbucking pickups with black mounting rings
  • Gold adjustable bridge with two posts and thumbwheels
  • Gold trapeze tailpiece with a black insert
  • 4x gold dome knobs
  • Pre-wired harness with four pots and yellow cloth-covered wire
  • Gold 3-way toggle switch with a black tip
  • Output jack with mounting nut and washer
  • Pearl-white pickguard with mounting screws
  • Black tapered jack plate with three screw holes
  • Assorted screws, nuts and washers
Hollow Body Archtop Electric Guitar Kit, Single Florentine Cutaway, Quilted Maple Veneer, Left-Handed is in stock.
Is this kit left-handed?
