Hollow Body Archtop Electric Guitar Kit, Maple Body, Ebonized Fretboard, Dual Humbuckers
SKU E75-RPBG-4812
$329 USD
$329 USD - $329 USD
Current price $329 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 2 – Dec 16 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Material: Laminated Maple
  • Binding: Single White
  • Upper Bout: 275 mm
  • Waist: 235 mm
  • Lower Bout: 384 mm
  • Depth: 83 mm
  • Width at 5th Fret: 46 mm
  • Width at 9th Fret: 49 mm
  • Width at 12th Fret: 52 mm
  • Width at 22nd Fret: 56 mm
  • Inlay Shape: Diamond
  • Shape: Classic Blues, 3+3
  • Tuners: Sealed
  • Unfinished hollow archtop body with two f-holes, two routed pickup cavities and a routed neck pocket
  • Neck with dark fretboard, split-block position markers and a drilled headstock
  • 1x black-covered humbucker with lead wire
  • 1x humbucker with chrome center bar and black surround
  • 1x large black pickguard
  • 1x small black bell-shaped cover plate with two screws
  • 1x wiring harness with pots, capacitors and chrome output jack
  • 1x chrome toggle switch with chrome tip, nut and washer
  • 1x chrome bridge with six adjustable saddles, two posts and thumbwheels
  • 1x chrome bar tailpiece with two mounting studs
  • 4x black knurled knobs
  • 1x bag of chrome mounting screws
Hollow Body Archtop Electric Guitar Kit, Maple Body, Ebonized Fretboard, Dual Humbuckers is in stock.
It has two humbuckers, one at the neck and one at the bridge. The controls are two volume, two tone and a 3-way switch.
