Mahogany MB-style Guitar Kit With Maple Neck and Ebony Fretboard
SKU MB-RMEB-3970
Build your own Mahogany MB-style Guitar Kit With Maple Neck and Ebony Fretboard using our DIY guitar kits.
  • Adjustable bridge and stopbar tailpiece set intonation quickly once the posts are seated
  • Four controls and a toggle switch mean plenty of soldered joints to keep tidy in the cavity
  • Material: Ebony
  • Inlay Material: Abalone
  • Shape: Semi-Styled
  • Nut: Black Plastic
  • Knobs: Black Plastic w/ Dials
  • Strings: Standard Steel
  • Finish: Black Finish
  • Maple neck with ebony fretboard and abalone dot inlays (unfinished)
  • 6x black sealed diecast tuners with bushings and washers
  • 2x black-covered humbucker pickups
  • Black adjustable bridge with posts and thumbwheels
  • 4x black knobs
  • Black neck plate with mounting screws
  • Black rear cavity covers
  • Wiring harness with potentiometers and 3-way toggle switch
  • Set of guitar strings
Unfortunately, Mahogany MB-style Guitar Kit With Maple Neck and Ebony Fretboard is out of stock.
