JBM 7 String Guitar Kit with Ebony Fretboard
SKU JBM7-RZEB-725
Current price $289.99 USD
$289.99 USD - $289.99 USD
Build your own JBM 7 String Guitar with Ebony Fretboard using this DIY kit.
  • Number of Strings: 7
  • Floating tremolo needs its spring tension balanced against string tension before the intonation will settle
  • Scale Length: 648mm
  • Material: Ebony
  • Number of Frets: 24
  • Inlay Shape: None
  • Shape: Styled
  • Nut: Black Locking Nut
  • Bridge: Locking Tremolo
  • Finish: Black Finish
  • Zebrawood 7-string guitar body (unfinished)
  • Zebrawood neck with ebony fretboard, no inlays (unfinished)
  • 2x black humbucker pickups
  • Black rear cavity cover
  • Allen wrenches
Unfortunately, JBM 7 String Guitar Kit with Ebony Fretboard is out of stock.
