WR Mahogany Bass Kit with Ebonized Fretboard
SKU WAR-RMEB-1
Original price $319 USD
Current price $289 USD
$289 USD - $289 USD
Build and customize your own bass with the W2 Mahogany Bass Kit. This kit is designed for players who want a standout body shape, strong low-end tone, and full creative control over the finishing and assembly process.
  • Number of Strings: 4
  • Material: Mahogany (2 pcs)
  • Scale Length: 864 mm / 34"
  • Radius: 12" / 305 mm
  • Number of Frets: 24 Extra Jumbo
  • Fret Size: Extra Jumbo (2.8 x 1.45 mm / 0.110 x 0.057")
  • Nut Width: 40 mm
  • Neck Pickup: Split Coil
  • Controls: 2 Volume, 1 Tone, 3-Way switch
  • Pickups: P-style Bass, J-style Bass
  • Bridge: Bass Bridge
  • Spiked angular bass body, unfinished, routed for a split-coil and a single-coil pickup
  • Neck with ebonized fretboard, frets and dot inlays fitted
  • 4x black bass tuners with bushings and washers
  • Black split-coil bass pickup in two halves
  • Black bar single-coil bass pickup
  • Black bass bridge with adjustable saddles
  • 3x black dome knobs
  • Output jack on a square black jack plate
  • Set of ball-end bass strings
  • 2x black strap buttons
  • Packaged Allen wrench set and one loose Allen wrench
  • Assorted black mounting screws and springs
WR Mahogany Bass Kit with Ebonized Fretboard is in stock.
It has a fixed bass bridge with four saddles. There is no tremolo.
It has two pickups: a split-coil pickup at the neck and a single-coil pickup at the bridge.
