JE-style guitar kit with 7-string Stripewood Body
SKU JE7-RZEB-885
Original price $299 USD
Current price $279 USD
$279 USD - $279 USD
  • Secure, encrypted checkout.
Build your own 7-string DIY guitar using this JE-style guitar kit with 7-string Stripewood (Reconstituted Wood) body and ebonized fretboard.
  • Number of Strings: 7
  • Number of Frets: 24
  • Inlay Shape: None
  • Inlay Material: None
  • Nut: Black Locking Nut
  • Bridge: Locking Tremolo
  • Guitar body with strong striped grain (unfinished)
  • Guitar neck with dark fretboard, striped headstock face and a black locking nut fitted
  • Black double-locking tremolo bridge with seven saddles
  • Black tremolo arm
  • 2x black tremolo posts with bushings
  • 3x tremolo springs with spring claw and mounting screws
  • Pre-wired harness with potentiometer, blade switch, capacitor and colored wire
  • Black dome knob
  • Black oval jack plate with output jack
  • Black rear tremolo cavity cover
  • Assorted black screws
Unfortunately, JE-style guitar kit with 7-string Stripewood Body is out of stock.
