Bolt-On Neck Single-Cutaway Electric Guitar Kit with Pre-Wired Electronics, Mahogany Body, Bound Ebonized Fretboard, Dual Humbuckers
SKU LP-RMEC-5891
Original price $259 USD
Current price $219 USD
$219 USD - $219 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 16 – Nov 23 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
  • Secure, encrypted checkout.
A single-cutaway kit with a bolt-on neck and a bound fretboard. The mahogany neck fastens to the body with four screws through a chrome neck plate, so there is no neck joint to glue or clamp. The ebonized fretboard comes with single white binding fitted along both edges at the factory.
The electronics arrive pre-wired: two volume pots, two tone pots, the 3-way toggle switch and the output jack are joined on one harness with plug-in connectors, so the wiring goes together without soldering. Around that: a solid mahogany body with no top veneer, white pearloid trapezoid inlays, two chrome-covered humbuckers, an adjustable chrome bridge with a separate stop bar tailpiece, and six chrome sealed tuners.
  • Bolt-on neck attaches with four screws and a neck plate, so there is no gluing or clamping
  • Pre-wired harness with plug-in connectors means no soldering anywhere in the build
  • The adjustable bridge still needs its four posts seated and the intonation set during setup
  • Mahogany is open-grained, so plan a grain filler step before a gloss finish
  • Joint: Bolt-on (4 screws and a chrome neck plate)
  • Radius: 12" / 305 mm
  • Side Dots: Black
  • Binding: Single White
  • Shape: Classic Blues, 3+3
  • Nut: Bone (pre-installed)
  • Bridge Pickup: Humbucker (chrome cover)
  • Bridge: Adjustable Bridge (6 adjustable saddles, 2 posts)
  • Tailpiece: Stop Bar (2 studs)
  • Tuners: Sealed
  • Knobs: Black Speed Knobs
  • Cavity Covers: Black (control cavity and switch cavity)
  • Truss Rod Cover: Black
  • Unfinished single-cutaway mahogany body, routed for two humbuckers, with a bolt-on neck pocket, four control holes, a toggle switch hole, a side jack hole and rear control and switch cavities
  • Unfinished mahogany neck with a bound ebonized fretboard, white pearloid trapezoid inlays, a pre-installed nut and a drilled headstock
  • 1x chrome neck plate with 4x neck screws
  • 2x chrome-covered humbuckers in black mounting rings, with screws
  • 1x pre-wired harness with 2 volume pots, 2 tone pots, 3-way toggle switch and plug-in connectors
  • 1x output jack with plug-in connector
  • 1x chrome adjustable bridge with 2 posts and bushings
  • 1x chrome stop bar tailpiece with 2 studs and bushings
  • 4x black speed knobs
  • 1x black toggle switch washer with rhythm and treble lettering
  • 1x black pickguard
  • 1x black rear control cavity cover and 1x black round switch cavity cover
  • 1x black bell-shaped truss rod cover with screws
  • 2x chrome strap buttons with felt washers and screws
The wiring is pre-wired, so no soldering is needed. Depending on the finish you choose, the tools below cover a standard build.
  • For setup: String winder, guitar tuner, Allen wrench for the truss rod and saddle height adjustment
Browse the full range of single-cutaway guitar kits, or compare the pre-wired single-cutaway kit with a maple fretboard and the set-neck mahogany kit with an ebonized fretboard.
Bolt-On Neck Single-Cutaway Electric Guitar Kit with Pre-Wired Electronics, Mahogany Body, Bound Ebonized Fretboard, Dual Humbuckers is in stock.
Does the neck need to be glued?
No. The neck is bolt-on: it fastens to the body with four screws through a chrome neck plate, so there is no glue and no clamping step.
Most of our single-cutaway kits have a set-in neck that is glued in place. This one bolts on, comes pre-wired, and has a bound ebonized fretboard with an adjustable bridge and a separate stop bar tailpiece. For a pre-wired bolt-on kit with a maple fretboard and a wraparound bridge, see the pre-wired maple fretboard kit; for a glued set-in neck with an ebonized fretboard, see the set-neck mahogany kit.
How hard is it to build?
Beginner, 1 out of 10 on our build difficulty score. The neck bolts on and the wiring plugs together, so there is no gluing and no soldering. The steps that take care are seating the four bridge and tailpiece posts, setting the intonation, and grain-filling the mahogany before a gloss finish.
