Mahogany Set-Neck Guitar Kit with Quilted Maple Veneer, Pau Ferro Fretboard
SKU NI-RMFB-3423
Current price $189.99 USD
$189.99 USD - $189.99 USD
Build your own set-in neck Mahogany NI-style Guitar with Quilted Maple Veneer and Pau Ferro Fretboard.
  • No binding, so no masking is needed when finishing
  • Top Veneer: Quilted Maple
  • Joint: Set-In (design might differ)
  • Scale Length: 648mm / 25.5"
  • Material: Pau Ferro
  • Number of Frets: 24
  • Inlay Material: Abalone
  • Nut: Black Locking Nut
  • Bridge: Locking Tremolo
  • Tuners: Sealed
  • Knobs: Gold
  • Body with figured light top, routed for two humbuckers, a single-coil and the tremolo
  • Maple neck with dark fretboard, frets, block inlays and a black locking nut fitted
  • 6x black tuners with bushings
  • 2x black humbucker pickups
  • Black double-locking tremolo bridge
  • Tremolo arm
  • Spring claw with three springs
  • Wiring harness with pots and selector switch
  • 4x gold dome knobs
  • Black tremolo cavity cover with a string slot
  • Large black shaped cavity cover
  • Black oval jack plate with output jack fitted
  • Black truss rod cover
  • Assorted mounting screws, washers and grommets
  • 3x Allen wrenches
  • Coiled set of strings with string tree
Mahogany Set-Neck Guitar Kit with Quilted Maple Veneer, Pau Ferro Fretboard is in stock.
