Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebony Fretboard, Chrome Hardware
SKU L5-RMEC-2
Original price $319.99 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
Build your own Hollow Archtop Body Guitar with Ebony Fretboard using our DIY Guitar Kits.
  • Material: Ebony
  • Inlay Shape: Diamond
  • Shape: Semi-styled, 3+3
  • Bridge Pickup: None
  • Knobs: Black Plastic
  • Neck with fretted black fingerboard and split-block pearl inlays
  • Output jack
  • Black triangular jack plate
Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Ebony Fretboard, Chrome Hardware is in stock.
1 humbucker, 1 volume, 1 tone
