V4 Ash body Guitar Kit with Rosewood Fretboard
SKU VR-RSRB-1
$299.99 USD
$299.99 USD - $299.99 USD
Current price $299.99 USD
Ready to unleash your inner rockstar? Our Ash V-style DIY Guitar Kit is like a muscle car you build yourself, but instead of horsepower, you get face-melting solos. With a solid ash body and stunning rosewood fretboard, this right-handed, bolt-on beast is the real deal, ready to hit the high notes of your craftsmanship.
  • Multi-ply binding must be masked carefully when finishing
  • Material: Ash
  • Binding: Multi-ply Black
  • Material: Maple w/ a Skunk Stripe
  • Scale Length: 24.75" / 628mm
  • Inlay Shape: Block
  • V-shaped ash guitar body, unfinished, routed for two humbuckers
  • Maple neck with rosewood fretboard, pearloid block inlays and nut fitted
  • 2x open-coil humbucker pickups with black bezels and ivory coils
  • Black bridge with six individually adjustable saddles
  • Black stop bar tailpiece
  • 2x pairs of black posts with bushings for the bridge and tailpiece
  • Wiring harness with two potentiometers and a toggle switch
  • Output jack with square black jack plate
  • 2x chrome dome knobs
  • Coil of wire
V4 Ash body Guitar Kit with Rosewood Fretboard is in stock.
