Basswood Semi-Hollow PR-style Guitar Kit, Carved Maple Top
SKU PRH-RBMC-513
Original price $329.50 USD
Original price $329.50 USD - Original price $329.50 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
Build your own PR-style semi-hollow guitar with this premium DIY kit. Featuring a basswood body with a CNC-carved solid maple top, dual f-holes, and a set-in mahogany neck with a rosewood fretboard dressed in pearl white diamond inlays and black binding. A rewarding project for builders ready for a step up in complexity.
Intermediate (6/10)
  • Set-neck joint requires precise alignment with wood glue and clamps
  • DIY wiring inside a semi-hollow body with limited access through f-holes
  • Semi-hollow construction requires careful finishing and masking around f-holes
  • Material: Basswood with Solid Maple Cap (CNC Carved Top)
  • Type: Semi-Hollow Chambered
  • Top Veneer: Solid Maple Cap
  • Joint: Set-neck
  • Inlay Shape: Split Diamond
  • Binding: Black
  • Nut Width: 42mm
  • Tuner Holes: 10mm
  • Controls: 2 Volume, 2 Tone, 3-Way Toggle Switch
  • Knobs: Black Speed Knobs
  • Basswood guitar body with CNC-carved solid maple top and f-holes (unfinished, semi-hollow)
  • Mahogany set-neck with rosewood fretboard and black binding (unfinished)
  • 2x humbucker pickups
  • Wiring kit (pots, 3-way toggle switch, output jack, wiring)
  • Adjustable bridge
  • Stop tailpiece studs
  • 6x sealed diecast chrome tuners with bushings
  • 4x black speed knobs
  • Round cavity cover
  • Back plate
  • Strap pins
Basswood Semi-Hollow PR-style Guitar Kit, Carved Maple Top is in stock.
