34 Inch 5 String EXP Bass Style Guitar Kit Mahogany Body
SKU EXPB-RMOB-1
Current price $289.99 USD
$289.99 USD - $289.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Aug 22 – Sep 5 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build your own professional grade 34 inch 5 string EXP style bass guitar with this mahogany body DIY kit. Designed for players who want aggressive styling and balanced low end performance, this kit includes a solid mahogany body, a bolt on mahogany neck, and an Rosewood (Engineered) fretboard with pearl white trapezoid inlays. The 22 fret, 34 inch scale setup delivers familiar feel and extended range tuning stability ideal for rock, metal, and modern bass tones.
This kit arrives unfinished and ready for customization, giving builders full control over sanding, staining, and finishing for a truly personalized instrument.
  • Headstock Shape: Edge
  • Body type: Solid
  • No. Frets: 22
  • No. Strings: 5
  • Neck Nut Width: 1.77" / 45 mm
  • Scale Length: 34" / 864 mm
  • Cutaways: Single
  • Pickups: Two Soapbar
  • Bridge: Fixed
  • String: Steel
  • Machine Heads: Closed
  • Truss Rod: Double Way
  • Electronics: 2 Volume, 1 Tone
  • Body Material: Mahogany (2-3 pcs)
  • Neck Material: Mahogany
  • Fretboard Material: Rosewood (Engineered)
  • Neck Nut Material: Black Plastic (ABS)
  • Hardware Set Finish: Black
34 Inch 5 String EXP Bass Style Guitar Kit Mahogany Body is in stock.
