Hollow Body Electric Guitar Kit with Acoustic-Style X-Bracing, Maple Body, Ebonized Fretboard, Single Humbucker
SKU E75-RPPB-5534
Original price $299 USD
Current price $279 USD
$279 USD - $279 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Dec 2 – Dec 9 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Around that body: a set-in maple neck, a bound ebonized fretboard with white pearloid inverted diamond inlays, one chrome-covered neck humbucker, a floating bridge and a chrome trapeze tailpiece. One pickup and two knobs keep the wiring simple, and single white binding runs around the top, back and fretboard.
  • Top: None
  • Upper Bout: 275 mm
  • Waist: 235 mm
  • Lower Bout: 384 mm
  • Depth: 83 mm
  • Side Dots: Black
  • Shape: Classic Blues, 3+3
  • Bridge Pickup: None
  • Tailpiece: Trapeze
  • Tuners: Sealed
  • Unfinished maple neck with a bound ebonized fretboard, inverted diamond inlays, a pre-installed nut and a drilled headstock
Hollow Body Electric Guitar Kit with Acoustic-Style X-Bracing, Maple Body, Ebonized Fretboard, Single Humbucker is in stock.
1 humbucker, 1 volume, 1 tone
What is X-bracing?
How hard is it to build?
Is it right-handed?
