Mahogany ST Guitar Kit w/ Maple Fretboard, Pre-wired Electronics
SKU ST-RMPC-29
Original price $229.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Jun 17 – Jun 24 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Jul 8 – Jul 22 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Orientation: Right-hand
  • Scale Length: 648mm / 25.5"
Beginner (1/10)
  • Material: Mahogany (2 pcs)
  • Material: Maple (2 pcs)
  • Radius: 12"
  • Inlay Material: Black (ABS)
  • Shape: S-style 6-in-line
  • Tuner Holes: 10mm
  • Nut Width: 42mm
  • Knobs: White Plastic
  • White plastic nut
  • String trees
  • Tremolo springs
  • Neck plate with screws
  • Output jack
  • Allen wrenches
Mahogany ST Guitar Kit w/ Maple Fretboard, Pre-wired Electronics is in stock.
