Singlecut Junior Solid-Body Guitar Kit with Spalted Maple Veneer
SKU LPJ1-RMRC-1
Current price $239.99 USD
$239.99 USD - $239.99 USD
Build your own junior solid-body singlecut guitar using this DIY guitar kit with a beautiful Spalted Maple Veneer, mahogany body & bolt-on maple neck, Rosewood (Engineered) fretboard, and trapezoid pearl white fretboard inlays.
  • Neck Pickup: None
  • Bridge Pickup: P90
  • Body with spalted maple veneer top, unfinished
  • Neck with dark fretboard and pearl-white trapezoid inlays, unfinished
  • Black soapbar single-coil pickup
  • Chrome wraparound bridge with two mounting studs and bushings
  • Pre-wired wiring harness with two potentiometers and capacitor
  • Black truss rod cover
  • Black plastic cavity cover plate
  • 2x black knobs
  • Set of strings
  • Truss rod adjustment wrench
Singlecut Junior Solid-Body Guitar Kit with Spalted Maple Veneer is in stock.
1 P90, 1 volume, 1 tone
