Hollow Body Archtop Electric Guitar Kit, Flame Maple Veneer, Rosewood Fretboard
SKU L5-RMRG-1
Original price $319 USD
Current price $299 USD
$299 USD - $299 USD
Build your own hollow body, semi-acoustic DIY guitar with Mahogany body and neck, flame maple veneer, F-holes, and single cutaway.
  • Floating bridge and vibrato tailpiece need careful setup for tuning stability
  • Binding: Multi-ply Ivory
  • Shape: Classic Blues, 3+3
  • Binding: Ivory Multi-ply
  • Bridge: Floating Bridge + Vibrato Tailpiece
  • Tuners: Gold Sealed
  • Pickguard: Red Pearl
  • Knobs: Gold
  • Finish: Gold
  • Hollow guitar body with flame maple top, twin f-holes and light binding (unfinished)
  • Guitar neck with rosewood fretboard, pearloid trapezoid inlays and bound headstock
  • 2x humbucker pickups with gold-colored covers in black mounting frames
  • Gold bridge with six adjustable saddles
  • 2x gold bridge posts with thumbwheels
  • Gold hinged vibrato tailpiece with arm and spring
  • Wiring harness with four potentiometers, cloth-covered wire and output jack
  • 3-way toggle switch with black tip, gold nut and washers
  • 4x gold dome knobs
  • Red pearloid pickguard
  • 2x gold strap buttons with screws
  • Coil of black wire
  • Assorted potentiometer nuts and washers
Hollow Body Archtop Electric Guitar Kit, Flame Maple Veneer, Rosewood Fretboard is in stock.
Is the body solid wood?
No. It is a hollow body made of laminated wood, which is thin layers glued together. The top has a thin flamed maple veneer and two f-holes.
