This is our complete catalog of DIY guitar kits. Every style we carry is here: solid body electrics, semi-hollow builds, acoustic kits, and bass guitars. Each kit arrives with a pre-shaped body, a carved neck, tuning machines, a bridge, pickups, and all the wiring you need.
We designed these kits for builders who want a real instrument, not a toy. The wood is properly dried, the frets are installed, and the hardware fits without modification on most builds. Your job is the finish work, the wiring, and the final setup.
If you are new to building, start with a bolt-on solid body kit. The neck attaches with screws, so alignment is forgiving and you can adjust it later. More experienced builders might want a set-neck or semi-hollow kit for a bigger challenge. Either way, our kits ship with everything you need except finishing supplies and a few hand tools. Browse the full collection below and filter by body style, pickup type, or price to find your next build.
4.6 / 5.0
7 Reviews
Solid Mahogany body right-handed PR Guitar Kit with Double Locking Tremolo, Quilted Maple Veneer. Full Specifications General Dexterity: Right-Han...
View full details4.5 / 5.0
8 Reviews
Beginner-friendly ST-style solid zebrawood body guitar kit with a bolt-on neck and white pickguard. Full Specifications General Dexterity: Right-H...
View full details5.0 / 5.0
5 Reviews
Build your own hollow body, semi-acoustic DIY guitar with Mahogany body and neck, flame maple veneer, F-holes, and single cutaway. Full Specificati...
View full details4.7 / 5.0
9 Reviews
Full Specifications General Dexterity: Right-Handed Number of Strings: 6 Size: Full Size Build Difficulty: Intermediate (7/10) Set-in neck ha...
View full details4.3 / 5.0
7 Reviews
Build your own Basswood ST style guitar with Maple Neck and Fretboard, Chrome Hardware. Full Specifications General Dexterity: Right-Handed Numbe...
3 Reviews
Build your own Thin Hollow Body Venetian Cutaway Guitar Kit with Rosewood Fretboard and Flame Maple Veneer using our DIY Guitar kits. Full Specific...
View full details4.8 / 5.0
5 Reviews
Build your own Hollow Archtop Body Guitar with Ebony Fretboard using our DIY Guitar Kits. Full Specifications General Dexterity: Right-Handed Nu...
1 Review
Build your own Mahogany body R41 Bass Guitar with Rosewood Fretboard using this DIY Guitar kits. Full Specifications General Dexterity: Right-Hand...
View full detailsThe TE Style DIY Guitar Kit with a basswood body is one of the most recommended kits for beginners and seasoned builders alike. Known for its class...
View full details4.1 / 5.0
9 Reviews
Build your own junior solid-body singlecut guitar using this DIY guitar kit with a beautiful Spalted Maple Veneer, mahogany body & bolt-on mapl...
View full details4.0 / 5.0
7 Reviews
Build your own solid-body double-cut guitar using this DIY guitar kit with a mahogany body & bolt-on mahogany neck with a beautiful rosewood fr...
View full details3.8 / 5.0
5 Reviews
Bolt-on neck F2 guitar kit with a mahogany body and neck, Ebony (Engineered) fretboard, and trapezoid abalone inlays. Full Specifications General ...
2 Reviews
Build your own E75 hollow body guitar with Mahogany Body and Neck, Spalted Maple veneer, F-Holes, and Florentine-style single cutaway. Full Specifi...
View full details4.4 / 5.0
5 Reviews
Build your own professional grade 34 inch 5 string EXP style bass guitar with this mahogany body DIY kit. Designed for players who want aggressive ...
2 Reviews
TE-style Guitar Kit with Alder Body and Mahogany neck and Ebony (Engineered) fretboard. Shop now to build your own DIY guitar! Full Specifications ...
1 Review
Build your own Mahogany LP-style body Guitar with Ebony Fretboard using this DIY Guitar Kit. Full Specifications General Dexterity: Right-Handed ...
View full details3.5 / 5.0
2 Reviews
Build your own E75-style hollow body guitar with Mahogany Neck, Flame Maple veneer, F-Holes, and Florentine-style single cutaway. Full Specificatio...
2 Reviews
TE style Guitar Kit with Ash Body, Flame Maple body veneer, and Maple neck with a skunk stripe. Shop now to build your own DIY guitar! Full Specifi...
4 Reviews
Build your own 7-string hollow guitar kit with a mahogany body, ebony fretboard, F-holes, and Florentine-style single cutaway. Full Specifications ...
6 Reviews
Build your own semi-acoustic DIY guitar kit with Flame Maple Veneer Mahogany body and Ebony Fretboard with beautiful Split Parallelogram Pearl Whit...
1 Review
Build your own DIY left-handed Ash body ST style guitar with a bolt-on neck and rosewood fretboard. Full Specifications General Dexterity: Left-Ha...
2 Reviews
Left-handed Devil-Horn guitar kit with a mahogany body under a quilted maple veneer, a bolt-on mahogany neck, and a rosewood fretboard with trapezo...
View full details2.0 / 5.0
3 Reviews
Experience the joy of creating your own music with our DIY Violin Bass Guitar kit! This short-scale (30" / 760 mm) kit includes all the materials n...
1 Review
Ever dreamed of crafting your custom short-scale guitar? It's time with our DIY kit, offering everything from a rosewood fretboard to a strong mapl...
View full detailsWe carry S-style, T-style, single cutaway, double cutaway, V-shape, semi-hollow, and several other body shapes to match your playing style.
Bolt-on necks are easiest to build and adjust, set-neck joints offer more sustain, and neck-through construction provides the smoothest upper fret access.
Most guitar kits use a 24.75 inch or 25.5 inch scale length, which affects string tension and the spacing between frets.
Check the pickup type, potentiometer values, and switching layout. Some kits include coil-split wiring for extra tonal range.
Every kit includes a pre-shaped body, a fretted neck, tuning machines, a bridge, pickups, pots, a switch, a jack, knobs, and all mounting screws. You supply the finish, solder, and tools.
Yes. You can swap pickups, change the finish, upgrade tuners, and modify the wiring. Many builders use our kits as a starting platform and personalize from there.
The raw materials are comparable to instruments in the 300 to 500 USD range. The difference is that you do the finish work and setup yourself, which means you control every detail of how it plays and sounds.
Yes. We ship worldwide from both US and international warehouses. Check the product page for shipping estimates to your country.
